Probably you have mised some of my posts.
I have already mentioned in stats that I traveled on motorway, using AC.
Let me elaborate Everything for you.
- I was curious enough to try this LPG stuff.
- I asked mechanics, got details from only two cooperative mechanics.
- Rest Goes below.
Yes until you put cylinder upside down OR YOU AT-LEAST PUT CYLINDER IN TRUNK DIAGONALLY SO THAT YOU COULD GET MORE GAS OUT OF IT DUE TO GRAVITY EFFECT.
Yes they charge Rs. 15 extra if they pump gas in cylinder. doesn't matter target cylinder is LPG or CNG or else.
Company rate in Islamabad is 1600 Rupees for 15Kg cylinder, means 106 Rupees per KG. You can get this rate if you exchange old empty cylinder with sealed(company filled) one. In this case LPG shops doesn't have to use pump....hopefully you get the idea. you get pumped gas @ 120 Rupees in Islamabad/Rawalpindi.
my stats: cost of Gas 106/Kg x 11Kg = 1166/-
what I mention in my post is 15Kg cylinder @ 106Rs./Kg in Islamabad.
Total gas consumed for 280Km ride = 11Kg. so cost of Gas becomes 106/Kg x 11Kg = 1166/-....Islamabad Rate.
I got 11Kg pumped in Lahore @ 105Rs./Kg.... If I had totally empty cylinder and I find the same LPG brand agency in Lahore, I could get cylinder replaced @ 90 Rs. per KG. hopefully you get the idea.... If you have POL gas cylinder then you can get it replaced only from POL gas agency...
I have not made any switch... What I have done is "unhook CNG cylinder from CNG pipe and put that CNG pipe to LPG cylinder". so there is no way to get CNG in piping for the time being.
Yes it can be accomplished but there are safety issues. One of the mechanic has suggested me.... we have to make sure that all piping and valves used in such a system are specifically designed for CNG as CNG system works @ 250 BAR pressure while LPG @ 5 BAR only. We dont want CNG pressure burst our LPG piping/valve or LPG cylinder. Using LPG in CNG system is quite safe but it is not true vice versa, You simply cant use LPG Piping/Valves/cylinder for CNG.
The simplest approach is to get LPG pumped in CNG cylinder. if you get 40Kg pumped, you can have a round trip Islamabad-Lahore-Islamabad. But atleast 5Kg will remain in CNG cylinder. In simple, get 40Kg pumped and consider it 35Kg for first time, in subsequient refills you will get pumped only 35Kg. (5 Kg minimum balance as banks keep Rs. 10000 minimum balance to have Account...lol)
If you choose to get CNG pumped later on, the LPG guy was saying that you can safely get CNG while you have 5kg LPG in cylinder as it(5Kg of LPG) will remain there in liquid form until it get the way to get out of cylinder....
I will be coming back from Lahore hopefully next monday. I will update my new stats...
