bro the only explanation i can think of is this:
Settings as we say are out means that fuel to air ratio is not right. So consider the following scenario,
you went to khattak, he did settings for you. Now at that time lets say he was able to get the ratio near perfect.
Next morning, the screws are still at same positions so ideally, the ratio should be same as last evening, but since the car is dropping rpm, it is obvious that something has changed which caused the fuel ratio to change and the screws are needed to be adjusted again. The only thing in this scenario changed is the amount of fuel.
As we all know, kits are basically regulators, so it is kit's job to keep fuel regulated i.e same amount should be coming all the time unless changed by mechanic. In this case, the regulator is not regulating the amount of fuel... Perhaps its because we are using cng kit for lpg(i.e its not optimized for lpg) OR the pressure of lpg keeps changing.
As far as solution for this problem, i cant comment. May be water pipes will work but i guess not... Do zia and asim have same kits as yours? there can be many reasons for lpg to be perfect for someone and not for other. advancer/emulator/different ecu/different car etc etc
u know once when u posted that ac on idling doesnt uses much cng so i tried it too for like 10min on cng n after that my idle rpm on cng went down near to 0 n i had to get its setting done again
on cng? aren't you using lpg, in any case, idle rpm dropping has nothing to do with consumption. Yes i said that on idle cars don't consume much even with AC. But if rpm is dropping, then its settings problem
here are so many screws how would i know which one is the idle speed adjuster when all u do is take ur arm there, yea screws cant move on their own but then how does cng setting gets out?
You have to get your arm inside lol otherwise it is hard to explain. The position of kit in civics is awkward and the good thing is that once you get your arm in, the closet and easiest screw you can reach is the idle adjuster. I at least have never got get hold/touch any other screw. Its the idle adjuster which comes in to your hand
