I'm quite sure Honda specced 5W-20 for the R18A with a 10,000km oil change interval, which necessarily means a low HTHS around 2.6. This is a simple engine, and I've run mine 195,000km on plain jane 5W-30. It's not uncommon to see these engines with 300k+ on them.
ACEA A3/B4 calls for HTHS > 3.5, so if it gives you peace of mind (as it would to me) you can switch to an oil that has that certification, but clearly Honda didn't think it necessary. Helix HX7 Plus is rated ACEA A3/B4 and is probably the cheapest available for 4 liters.
