MOD EDIT:avoid bumping the thread for more than once in a day,else your thread wil b closed.consider this as a warning
hey all i am selling my ma audio hk598 amplifier,it is better than korean amplifiers like solid audio etc,coz it's original and it's ratings aren't fake.............it's ratings are:
4-Channel Class AB Amplifier
400 Watts RMS x 4 Channels @ 2 Ohm Stereo
200 Watts RMS x 4 Channels @ 4 Ohm Stereo
400 Watts RMS x 2 Channels @ 4 Ohms Bridged
2 Ohm Stereo Stable
Tri-Mode Capable (Stereo & Mono)
Platinum Plated Block Terminals
Platinum Plated Low Level RCA Input Jacks
Fully Regulated Power Supply
Thermal, Short, and Overload Protection Circuitry
Power and Protection LED
Quiet Fan Cooling System
Stainless Steel Finish Heat Sink
Double Sided Black Epoxy PCB Board
Input Sensitivity Adjustment (Gain)
Variable LPF/FULL/HPF Crossover
Variable High Pass Filter: 40-250Hz
Variable Low Pass Filter: 40-250Hz
Variable Bass Boost: 0-18dB
Channel Separation: 60dB
Frequency Response: 20-20kHz
THD: <0.05%
Signal to Noise: >90dB
Input Voltage Range: 200mV -4V
Input Impendence: 10k Ohms
Full MOSFET Circuitry
Fuse Rating: 40A x 2
Dimensions: 13.7" L x 12.4" W x 2.7" H
DEMAND: 8.5K
CONTACT : 0322-2240269(ALI)
