I'm using Homage Matirx 1001 does this UPS provide any adjustments? here are the inside images
I have a silly question in mind that what is the maximum voltage power of battery we can use in car for utilizing? Can anyone here automobile expert tell us?
Ishtiaq brother my ups is desi , pics are below
No dear....it has no adjustable parameters...u have live with it as it is.
O dear....very old kit with jugar avr system.....by spending 1500...u can upgrade it...the best option
2nd option is...to adjust battery low variable...
but it didn't work,I bought imran brothers f72 kit but it has also same problem and my 750rs are wasted.
why not ic 105???
Bro where can i get original IC 105 by imran & Co. In Lahore?
Hall Road , Mughal center .........or any ups spare parts retailer shop....u can easily get
Aoa.Bhai aap se pochna tha k main nay desi type ka UPS banwaya hua hy.jo k 1000 watts ka hy.copper ka hy.iss k saath me kam se kam aur ziada se ziada kaun c amp ki bettery laga sakta hoon.?2010 me lia tha abhi tak tu repair nhi krwaya.Pehlay main new battery excide 200 ya 190 layta tha.max 1 year k baad bettery khatam ho jati thee.main 3 years se recycle jo betry milti hy woh lagata hoon.last year main nay apny UPS k saath 120+ 120 ki bettery lagai.per itna backup nhi mill saka jitna hona chahiay tha.UPS tu mera single bettery wala hy.per double battery iss liay lagai thee k shayed acha backup milay.per nhi.plz suggest k 1000watt k saath kaun c bettery theek rahay ge aur mera backup kaisay ziada ho sakta hy.plz help yaar
Isthiaq brother I know about ic 104 but not about ic 105
Brother you cannot use double battery with a single battery ups because your ups is built on 12v where as for two batteries it has to be 24v. This is the reason i think it did not give backup on two batteries. If you want to use two batteries 1st convert your ups to 24v meaning both transformer and kit will have to be changed.
Once i was a local ups user but not any more ... i had 1000 watts and it was 12 volt dc ups ... but i installed 4 X 12 volts dry used battery in parallel and backup was like 8 to 10 hours ... so if u want increase ur backup time than install batteries in parallel. ..
is it safe for the batteries to connect it in parallel. on a 24v ups.
