Its good meter. Will cost you around 2500. If you want to save some bucks then can go for some chinese clamp having AC/DC both amp measurement. But it will have a little difference in reading.
The chinese clamp meter available in market dont hve dc current measurement as i baught one today and wasted my 500 rs as its not refundable.Now i was thinking to buy a simple probe multimeter of uni T as it have both dc and ac current measurements.but if u recomend uni t 203 then i will purchase it as rather than buying cheap products daily its better to buy a quality product for once.2ndly plz confirm than can 203 measure current by using probes.
203 can only measure current via clamp. Ishtiaq bro can further recommend about probe multimeter
I hope this clears the confusion.
Current from batteries measure krne k lie panel ammeter le lijie.bijli wali shop se mile ga,200-250 k qareeb.install it permanent in series with batteries.it will cont show the charbing as well as load current from batteries.
Zyrak bhai panel ammeter ki koi pic upload kar daien ta k idea ho jaey k wo kesa hota hy.And what are the voltages provided by a healthy battery.One of my battery is giving 5 v at its terminls whereas the other one is giving 11v.
Voltage should be no less than 10. 5 means battery is dead.
Here are the pix of ammeter attached with batteries.u can attach it anywhere(either with positive wire or negative)
Thanx brother
AC ya DC dono trah k meter hi kaam dein ge
Matlab same ammeter can measure both type of currents?
Yes. I have installed it permanently to batteries, kisi anamolous behaviour ki soorat mein current fluctuate krta hai to idea ho jata hai
N frnds main ny batteries purchase kar li hain UGS 175 now plz tell me how to set charging current,cut off voltage and voltage which ups should provide at back up mode.My card pic is already uploaded.
Cutoff viltage per batter 14.2. Yani 12v ka ups hai to 14.2 pe rkhein, 24v ka hai 28.4 pe. Batteries full hone pe yeh adjustment hogi
My ups is 24 volts and kesay hogi ye adjustment plz discribe a lil .meray card ki pic uploaded hy wahan sy dekh k bata daien k kon sy screws sy ho gi ye cheezain set.
Yaar apke card ki battery full wala screw(variable resistor) ghaib hai.bat low r current wali k centre wali hai.jo yellow 2 screw hein,unki close ki foto upload krein ge?
Ok bro ghar ja k karta hun.phr ap bata dena.
Kit pe check kijie ga, jis screw pe battery full likha hua hoga, us se full battery ki adjustment hogi.agr ap detail se discuss krna chahein to 03007605122 mera no hai, i will be with a ups expert after 5 till almost 6:30
Ok bro will contact u inshallah amd this is a close pic.
Battery full adjust krne wali apki variable resistor hi ghaib hai
