Please correct me if I am wrong, this is what I have understood from this forum and a pamphlet distributed by AGS. Batteries will be 2x110amp (24volt system).
1a) If I prepare my electrolyte I should put one part of Sulphuric Acid into 2 parts of water (I need 20 litres) so 6.66 litre of acid and 13.33 litres of water and then I should let this cool down over 24 hours and check gravity and try to bring it to 1280 or alternatively by adding acid or distilled water. If I am not able to source good quality Sulphuric Acid from Karachi then I will go for Pyro premixed 1250 electrolyte from Lahore and pour that in batteries
2) Once electrolyte is poured, I will wait 30 minutes and then connect charger which will be 11 amp and 24 volt since 2 x 12v 110 amp batteries are connected in series.
3) I will wait until the voltage reaches 15 volts. Once the voltage is 15 volts I will check gravity in each cell and it should be 1250 which would mean that initial charging is complete now and if electrolyte level falls below low mark I will fill it up with distilled water.
Also at 10% charging rate what should be the time till volts reach 15 mark as I will be using external charger and not the UPS when charging for the very first time.
Please tell me what I have missed and give me more suggestions.
