Bro today I checked the new Phoenix UGS 175 batteries I got in April 2015 as per your recommendation. The UPS was charging them since 5 hours so I got suspicious. When I checked the amps, UPS was charging at 1.5-2.0Amps although the batteries showed 27.30Volts across them.
There has been an issue with Wapda not sending proper voltage since a few days ranging from 200-210Volts and when I checked it showed 213Volts, so I thought maybe that's why it's charging so slowly and at only 2Amps.
Then I removed the caps and checked the electrolyte level, it was just a little low in a few cells. I took S.G gravity and it showed around 1250 in a few cells only, mostly were 1200-1230 and some were 1150-1200. Although the batteries run the whole house just fine during 1 hour of loadshedding, they are taking too long to charge fully. Could be due to low voltages from Wapda, but can't be sure!
So I'm a bit worried now that I've used Pyro Electrolyte since the beginning in these batteries and the batteries are showing signs of death in just 3 months.
What should I do? Should I take them back to the battery guy and have them checked again? Or should I run some more tests (such as discharging the batteries fully to see the total hours of backup) myself to confirm???
