@unstopabl3
Please give more details:
What is the charge cutoff for your batteries? is it more than 29.2V or less than 28 or around 27 or even lower?
What is the charging amperes when the batteries are charging? Since these are UGS 175, so they are 135AMP batteries according to Phoenix.com.pk then 2x135 batteries should be optimally charged at 13.5 amp @ 24volts
What is the drain cutoff of your batteries ? Do you take them too low such as 16 amp or do you cut them off at 21 to 22 volts?
How do you top them off? Which water you choose? if branded battery water then which brand?
When you initially charged them? How much did you charge them? You should have charged them @13.5 amperes and should have taken them to at least 29.2 volts for the initial charge although I saw a poster by AGS where they say to take 12v battery to 15v (so 30v for 2 batteries) initial charge but I think that's controversial.
