First, your question regarding AC and DC thing tells me that your fundamentals on electrical subjects is very weak. Obviously if you are taking the measurement on battery terminals and battery wire connected to positive or negative terminals then you are measuring DC voltage and DC current.
Bhai I knew it was DC voltage but the guy at the UPS shop made me confused about the charging current and I didn't want to set a wrong value as on the clamp meter both AC as well as DC reading were being shown for current. So just to confirm one final time, whenever I'm measuring Voltage or Current by attaching the clamp meter on the battery, I should always select DC setting??? As right now my UPS is set at 17.50A when checked in AC mode and around 7.50A when checked in DC mode, so I should increase the charging to 15A while being in DC mode right??? Just confirm this please :P
The process is time consuming for you as still you are in learning stage. Otherwise its quick. I gave you a hint to increase the charging rate on temporary basis during the cutoff adjustments so that you don?t have to wait longer to see if ups hits the required cut of voltage or not.
Clarify this, that cut off voltage is a voltage once ups will stop charging the batteries. If cut off voltage has decreased on anti-clock wise rotation then it will increase on clock wise rotation of the variable.
Thanks I have successfully set the cut-off at 28.25V, but I was thinking to lowering it to 28.15-28.20V as it takes a lot of time for the batteries to reach 28.25V as the charging rate is only 2-3A after 28V. What do you think?
I right now don?t have a video recorder as otherwise I would have made a video for you. Set the output voltage on 250 volts right now as still your batteries are not fully charged. If it will be fully charged then you may end up experiencing 300 volts at output. To set the output voltage, rule of thumb is that charge your batteries fully and then adjust it by bringing it into backup mode.
Yes, that's how I have set it bro.
Output voltage is set to 260 volts maximum so that once batteries will discharge then output will also decrease from 260 till it will touch 230 or 220 volts. If it will go below 220 then may end up burning few adopters or tvs etc. so by doing so , we have defined a windows and if you will increase it more then again it will end up burning something else. If less is bad then more is also bad;
I understand what you are saying, you have already mentioned this in your OP, but my question was does using 250-265V output instead of using 270-280V provide more backup time from batteries or is it same???
