REPORT FOLLOWING PARAMETERS:
I have created a Small Chart for people who think, their UPS is not adjusted properly. Please report your readings by following this chart
1) How many batteries are connected with your UPS system along with AMP hour Rating of batteries, time once these batteries were bought , Ratings of your UPS. Along with intensity of Load shedding in your region and backup time of UPS.
2) Voltage Across batteries terminals before UPS stops charging and individual batteries
Description: You will need to sit near the batteries before you feel that charging is about to stop, plug in your Voltmeter and measure the Voltage against each individual batteries and combined Voltage of both.
3) Note the readings of your UPS line as soon as it enters into loadshedding.
Description: Take your Voltmeter and plug it to AC line and measure the Voltage.
4) Take Voltmeter and measure the Voltage across the batteries terminals , individually each battery and across AC line after 1 hour of Load shedding.
5) As soon as UPS starts to beep before it is about to shutdown, measure the Voltage across the terminals of both batteries, individual batteries and that of AC line immediately.
6) Report the charging rate if you have AMP meter
7) Report the S.G of each cell using Hydrometer.
I will instantly tell you the problem with your UPS system or with batteries. Kindly report the reading in following format.
1) Quantity: 2, AMP –HR 150 AH, Time: 1 year, Rating of UPS 2000W, Full load time: 2 hours on full load.
2) Before Charging Stops: 28 Volts, 14 Volts, 14 volts
3) 255 Volts AC
4) 22 Volts DC, 11.5 Volts, 10.5 Volts, 235 Volts AC
5) 20 Volts, 9 Volts, 11 Volts, 205 Volts AC
6) @12 A
7) Second battery: 1250, 1250, 1250, 1240, 1260, 1200 First battery: bala bala
From this example reading what I conclude is
1) Ok
2) Ok
3) Ok
4) 2<sup>nd</sup> battery is week.
5) 2<sup>nd</sup> battery is week but flush may restore that.
6) Ok
7) One of the cells will be dead very soon if action is not taken right away.
