Question: Nice Thread. dont u think that UPS on the continuous float charge will ultimately effect the life of battery.
Answer: No. at 28 Volts and 1 AMP of charging will not say anything to your batteries.
Question: because these batteries are basically made for vehicles not UPS and there is automatic charging cut off system in vehicles.
Answer: what other solution do you have as we donāt have deep cycle battery available here in Pakistan. Because of Monopoly from manufacturers.
Question: my 2nd question: people generally confuse the battery product name with the amp of batteries for example AGS or Exide GL50/ NS50ZL battery is actually 36 or 38 amp battery so dont u think that the formula for charging i.e amp/10 will lead to wrong charging amp
ANSWER: Yes somewhat, mostly datasheet does not comes with battery and this information is also mostly missing on manufacturers website. So mostly NA 50, NS 65 corresponds closely with 50 AMP-HR or 65 AMP-HR. Most of local UPS has three options to charge the batteries and that is either 5 Amperes, 18 Amperes and 28 Amperes so we know if its NL 220 then it would be roughly between 180 AMP-HR to 220 AMP-HR so 2[SUP]nd[/SUP] and first option can be choose based on our requirement. If you know exactly then thatās is an ideal scenario. This has already been discussed in details in previous posts.
