What will be the price of AGS 175 and Volta 200? I have been using volta previously and they never failed to give good backup time and lasted for 3-4yrs easily.
AGS 175 @12000Volta 200@14000
in rwp dealers are asking 14800 for ags 175 and 14900 for volta 200 17200 for ags 200 old battery for 3200 200AH volta
Dear where from u got so high rates? Very high price dear. Check from sadar and peer wadhai..
these are rates of main markets i don't know but they have revised price list after every 5-6 months which increases battery price 400-500rs. I checked from Melody market isb then national market rwp. Last time when i bought volta 200AH in 2012 i gave my old volta 175 with 8000rs cash. old battery was adjusted for 2500 total 10500rs volta 200AH in 2012 now volta 200AH 14900 if you stress a lot then they might give it for 14500rs and Ags 200 for 17K final.
price of ags 50ah for car?
fr0m where d0 u buy ths????
Fr0m where????
@talhawaleedBro i have checked my battery with a hydrometer, all six cells are in green area marker. Battery is one year old (home tap water used to level it, and is never flushed) since all the cells are in green area of hydrometer do i need to flush my battery??
No need of flush, just get it recharge it at low ampere for 24 hours.
What is more important for long backup and long battery life with ups. Thickness of plates (21 plates) Vs. Number of plates (23 plates) ?
what abut ph0nix???? i bought 175 of 12000 is this fine???
So far battery is good not giving any problem. Still i should get it recharged? Plus, a 24 hour charge will charge the battery more than 14.4 volts is it good to charge the battery this much??
Charging for 24 hours will not overcharge the battery. In fact, you can put it on charge for days as long as the charging current is low and the charger is of good quality which cuts off when battery voltage reaches 14.0.
Oh oka. I thought he said Continous 24 hour charge.
It is going to be continuous but you need to keep max charging current low. The charger will automatically cut off when the battery is fully charged. But make sure you do this with an automatic charger that has variable setting to adjust maximum charging amperes. Something like the charger below.
Thicker battery plates deteriorate slowly as compared to thinner cell plates. Having more lead, these plates hold charge greater than thinner.Long back up is reciprocal to long battery life.
What is your city where from you purchased the battery??? Here is its price is 11300. Asking price 12k but after a little negotiation , 11300 to 11500 final rate.
Flush procedure is done with sulfated batteries only. Your battery is fine. If you feel a little less backup time than, You should get it recharged, other wise no need.
Oka. Actually @talhawaleed suggested to flush the batteries every 6 to 8 months.. Thats why i was asking..
