Issue in top speed and pick
when i first got the chance to Floor mehran on M1 with iridium plugs and 8mm wires bought from Shoba i was really Disappointed with results car was hitting 110km/h MAX on petrol i was so mad but in this i noticed a few things which were wrong in my car
1 Cv joint of right axel
2 Cylinder Packing it made dar dar sound like old taxies after 80Km/h mark
3 and wires from shoba had no life in them they were used and abuses
so excpet for CV joint i changed wires to new 8mm which are cheaper then shoba wali Kabuli wires and Cylinder Packing plus whole exhaust had wholes so repaired it all got her tuned from ECRON center and after a few days i hit the M1 again plus similar iridiums were in it and this time results were amazing mehran ha 165/70/12 tires and speedo was showing 130 so u can guess what it was in real speed as big tires cause speedo to give an error 100 in speedo = 112.2 Km/h in real
Ignition Coil replacement
as most of mehrans have OIL ignition coil which Comes FF and it sucks it has a limited life and mechs do make a mistake when coil dies they assume that head gasket is gone and which leads to other problems.replace coil with magnetic coil which Alto and Cultus use its way better and gives an edge in starting costs were low when i did this 600 for the coil brand new but now i herd its for 1500 or something comes in a triangle box.
Front Guarder or GADRI
as time passes Front Guarder or GADRI become rusted and weak which causes problems for mountings of the front jumping rod a new Front Guarder or GADRI is about 1000 and 4 bolts hold it in place on a non accidented car its not a big job Front bumper needs to be opened and jumping rod and 4 bolts and its the reverse process while fitting but a car which had some accident then its a job in which a denter makes some $$$$ but there is always a way around intall gaudri and all stuff and see if there is some difference on alingment of bolts of front engine mounts cut a whole with welding torch in the engine mounting plate and its easy and also make adjustments to the jumping rod u can make tires placement in the wheels where they will fit but go for some good dentor so frame can be pulled out will cost more but its the right way
