sardarsaeed: That is great.Please post some output shots for the benefit of our members.
Regarding the high beam, since its a dual filament bulb, adjusting it will affect both the low beam and high beam, so I would suggest to adjust it to the point which is the best compromise between high beam and low beam.
If you use low beam almost all the time, then let the bulb remain as is.
HB Thank you very much.
I would strongly vouch against installing HID's in your car as you will loose the current visibility.You can buy better bulbs such as the Phillips X-Tremes.I think your Pejaro uses H4 bulbs, if it does then Phillips X-Treme are the best bulbs to get.
and yes, I wish HID kits were banned everywhere.
