Well everyone has his own opinion. I have a very bad experience with Mitsubishi Heavy Industries Split. Its a 1.5 Ton. Its problematic since day one.
Problem 1: If you fill the gas to desired pressure, the cooling is great(monetarily), but the compressor heats up and goes to thermal shutdown in a minute. You will see the AC running for hours and at times it will give chilling output, but only for a minute or two for every tens minutes of observation. If you reduce the gas pressure, it works continuously as its never able to cool to desired level and never trips. But it doesnt chill the room either. The warranty sucks big time. Seller is not responsible for fitting and warranty. Fitting guy (a separate party)is responsible for filling a warranty claim, only if it is approved as an authorized installer by importer. And we all know they work hand in hand to make sure not such thing happens
However I've seen Mr.Slim in operation at my workplace, my cousins home. Work like a charm. Make you freeze in scorching heat levels outside
Problem 2: Common to all Mitsubishi
You have to purchase separate piping kit with them. Other brands offer atleast 10feet of copper piping along with the units. But Mitsubishi never offer an inch. Also, the main unit power cable has to be installed to outdoor unit. Most of the houses have AC switch already installed close to the place where they want to place the inside unit. You have to purchase, a thick wire to carry it back to outdoor unit, and then a thin wire from outdoor to indoor to signal inside fan. Hence more wire and piping cost.
Verdict: If you still have an urge for mitsubishi, the older 2009 Model Mr. SLIM is far more superior in performance and reliability. If cost is an issue, I would recommend HAIER, Samsung, Orient but never a Mitsu. Heavy Industries.
