The lightest one is called " Zero" shade which holds the sunlight and doesn't attracts the cops.
I would disagree with all of you in putting a dark tint on the rear screen because:
It increases the chances of accidents because if you have to brake suddenly, the car coming from behind cannot see thru because of the black tint causing accident. so u can do a mild tint in the back screen.
Secondly u will have problems while reversing especially at evening times with no camera installed.
So why the hassle.
Basic things to cool the mehran:
Tints, light on all four and back, dark on small quarters.
Put a namda or grey foam beneath the carpet because mehran silencer pipe transfer too much heat from floor which u can check by touching near handbrake area after driving for an hour or so.
Find small holes and crevices from where the outer air comes in or the cooling escapes. close them as much as possible.
Cover the dashboard and use the direct of fan on face only.
@sayedarsalanali
@MuhammadWaleedMirza
@junaidahmad463
