You listed the readings in different units
Mehran produces 39.5 HP at a decent 5500 rpm. Due to its relatively flat torque curve, it can access most of its power in the low-mid rpm ranges; i.e. normal driving.
Daihatsu produces 43 HP at an outrageous 7200 rpm. It has to spin at 1k rpm (4k vs 3k) higher to access its peak torque output. My point exactly. Try driving it in the 4k-7.5k range in every day driving, and then see exactly how 'reliable' it can be.
As for the turbo, it is better compared to a turbocharged Mehran (Alto Works JDM) than the normal NA motor. I also assume that you read the post by Xulfiqar about overheating the turbo on the motorway.
