My Passo model 2008 got into major accident from front side resulted in both airbags deployment. I got it repaired from Workshop in karachi at Garden area. but when car was powered on, engine check light prompted after 5 min of engine start. when error checked through scanner, it gives trouble code of P1510 with unidentified DTC. Upon clearing from Scanner, it did disappeared. But on 2nd start up, it appeared again & not being able to be cleared from scanner. Moreover, there is some mysterious sound coming either from timing chain or airhose leakage from tappet cover ( suspected from my visual inspection) for only 10 seconds, when accelerator is releases after given it max. But this sound goes off immediately when i give little accelerator again. I need urgent help from Pakwheelers community who faced the same error as i am totally stuck on this error.
Plz recommend me good EFI Engine mechanic or Japanese car specialist mechanic in karachi area. As this engine check light does not give accurate fault indentification. I will be really grateful.
Regards
Khurram Khan
