I bought Civic 96 a year ago. Drove it for daily use and now I plan to build it as follow. I need your feedback and all experts are welcome to comment. I'm from Lahore.
Where can I have engine compression test done to see if engine is still healthy
Where can I get coilovers from?
Where can I got projectors for my 96EK?
What's the best engine I can Look for a swap.
Hi buddy. Thanks for reply.
Can you share which workshop?
Most of the import services are expensive for me. but I'll give Bilal ganj a visit
Do you know any shop/dealer who can hook me up with good projectors. Again the import service seems expensive for me, unless you can give me a better option.
I can afford 60k or 65k for engine swap.
D17A is a decent option as well though I'm not sure about the availability.
D17 is best to swap
Best is to swap projectors in an aftermarket headlight assembly.
An example of my EG
That is some neat work. Did you swap yourself? I can try attempting same if there is a guide or something.
Inbox for more details
Ma Sha Allah!! These look good. I too swapped Bi-Xenon projectors but the light output from yours look alot better (mine is good too but yours is better).
Also, is that a multi colored shroud?
Yup the halos are remote controlled multi colored ones
Bump
Looking for more suggestions on engine swap for my EK.
I am looking for a good stock performing engine, easy to install.
I'm from Lahore.
I would suggest you get a D16 VTEC. Not really high performance, but it's good.
Go for D15B 3 stage vtec P2J.
D17A Japenese
How much would it cost? Is there any alteration required?
D16Y8 available in mint condition in lhr. Inbox for details.
D17 is bolt on for ES, well it fits on EK too but D15 and D16 are good for EK and do look good in the bay.
How do you compare D16Y8 with D15B 3 stage vtec.
