next again fog lamps 🤣🤣🤣
Looks really niceee, can't change the digital panels light too?
all lights can be changed but will look odd i think .
brother c9st kitni ai and also result kesa he
you asking about the meter ??
Yes bro
well 15 rs for the leds thats it , did it myself so saved the labour .🏻🏻
Is there any soldering needed.Also dear brother is it an easy diy.
yes soldering is required and that to micro as the leds use here are 0805 leds and if you know soldering it can be a diy .
these 3 leds need to be changed and if you want to change the dispaly colour of mid you can do that aswell just change the leds .
thnk u sir.Rly appreciate it.
sweeeeeetCare to explain this DIY to brotherthnx
the steering part i did my self but didnt know how to wire it with the clock spring so had to get that part done from an electrician in sultan ka khoo .
th spiral cable is oem it has one point extra in the spiral so th guy utilised that pin .
i used a pin grinder to cut the sides of the airbag , P.S can get a Japanese air bag to avoid the cutting and save this one but in my case i didnt wanted it to look odd .
wiring from head unit is simple you need three wire one is ground and rest are key 1 and key 2 that part i did myself and that varies from headunit to headunit .
how did obe point siff8ce for all the c0nnections.I mean each button needs a different wire and pin right or wrongAlso where did u source the buttons
