no it doesnt work like that in a toyota is need 3 wires to work in suzuki it needs 1 wire and in some cars there is only one wire . there is a chip inside that sends the pulses and those pulses are recognized by the headunit .
well buttons were sourced from a friend of mine for 5k .
and as it is a suzuki it only needed 2 wires one for ground and one for key 1 .
but now i can do it myself 🤣🤣🤣 i saw that guy doing it asked him question and all he said was " bhai hm bhi laga laga k check krty hn th seekhty hn "
Brother can you help me out as well plzI need them too
well sure i can , but i cannot promise you this price i will ask him give you his number you can go there and get it by yourself .
currently this was the cleanest and the only piece he had got it from a madza steering .
and yes he took 2k for the wiring and everything .
Yes plz do share his contact info with me.
Any new mods done in your car?
finding the rims daihatsu ones and unable to find those ,
any help finding these
bro can you share how you installed the puddle lamps? as i got some from ali express to install in the side mirrors and trying to find how they can be fitted. Also who can make these type of acrylic rings for fog lights? I also got fog lamps installed in my vitz 2015 but the edges are not really uniform so it looks bad. need to do something about it
nice work done, keep it up
i will share you a diagram that how you can wire them so only that lamp operates which door is opened and not all , plus can you share me the pics of fog lamp rings you talking about so i can then suggest you .
these are mira 2018 shaped rims. can be found in used. i would suggest to get RS turbo rims......the rs rims looks cool
I need some sort of garnish to cover these holes up. Originally in this model there comes a chrome garnish around the fog lampsUploading... The holes i got made for fog lamps were accurate. But after adjusting them they are tilted a bit upwards i will get this grill cut a bit more from the top part of the fog lamps
