Sir you are most welcome.
I am lacking complete knowledge about ABS systems, so for the time being, we will stick to the current braking set-up at least till the current jobs are completely done i.e. engine mechanical, engine electrical, AC, denting/painting.......
Sir I would like to get a lead from you on what is practical, If you throw it up I will definitely work on ABS system. As far as I know, I have never seen B13 Hubbs in bilal gunj or scrap market which carry an ABS system.
One lead to go forward in this direction I will give first up is the half cut I am working on, of N16, does have ABS System and it has the routing, plus it has the Hubbs but it will be only for the front and I will never be able to find the rear hubbs for B13 with discs or for that instance ABS. Plus the ABS wiring/piping will be cut off from where the half cut is cut off.
