Updates.......
Swing arm overhaul kit with OEM replacement parts.....
how much the ballstuds costs?
@zee82
Rs. 1800 brother.
I Doubt They Are Genuine OEM Replacement....!!!
Just Make Sure They Have Lube Inside...They Never Have It Inside I Know......Get The Proper Spec GREASE For These ....!!!
Don't Have Some Good Experience With These OEM Replacements
They are empty from the grease...... name the grease ?
I Don't Know Exact Name But You Can Use Following
NLGI-2 Type Grease In Tubes....
You May Find It In MOBIL Or Other Similar GOOD Brands....!!!
A Good Ball Bearing Grease Will ALSO Work Which Is Capable Of Holding On High Temp And LOAD Capacity
NO DESI Allou Marki AND MP Grease PLEASE....
O twadi kheer.... jata hoon market dobara and will find it.
Koi kam ki grease nai mili so hum ney paa kharadiye ki hi grease laga di hey
Okay here are the denting updates for today......
The left side new doors are also in place and adjusted as well..... MashaAllah they are aligned perfectly and also opening and closing with a slightest touch...... again excellent job by denter.
As far as mechanical is going, main gadree is installed again after servicing and hubbs are also placed along with shocks, so tomorrow Inshallah engine will be hanged with chain hopefully to test fit it and we will check for mountings.......fingers crossed.
Rear side is in preparation for paint...... I hope it will be coming along soon.......
Again, doors are aligned beautifully........
RBI is not an OEM replacement. Do not trust everything Muneer or Abid Autos tell you. Any news on my O2 sensor?
As Expected ....Ball BEaring Ke Grease Nai MILE??? A Good Brand Imported Grease SHOULD Be There...Have To DIG...!!
There is a liquimoly dealer in muslim town, might have the grease
Sent from my SGH-T989 using PW Forums mobile app
you talking about this......
Today's updates......
Today, I provided wiring to Hafiz Sb so that he can start work on wiring.....
Hafiz Sb inspecting the wiring and seems quite satisfied :)......
Hafiz Sb started fitting engine bay wiring.....
