Hi guys,
Only 2pcs of brand new sealed pack devices in stock.
Display current sensor data, including:
Engine RPM
Calculated Load Value
Coolant Temperature
Fuel System Status
Vehicle Speed
Short Term Fuel Trim
Long Term Fuel Trim
Intake Manifold Pressure
Timing Advance
Intake Air Temperature
Air Flow Rate
Absolute Throttle Position
Oxygen sensor voltages/associated short term fuel trims
Fuel System status
Fuel Pressure
Many others...
Multi-Protocol Support:
1.SAE J1850 PWM(41.6Kbaud)
2.SAE J1850 VPW(10.4Kbaud)
3.ISO9141-2(5 baud init,10.4Kbaud)
4.ISO14230-4 KWP(5 baud init,10.4 Kbaud)
5.ISO14230-4 KWP(fast init,10.4 Kbaud)
6.ISO15765-4 CAN(11bit ID,500 Kbaud)
7.ISO15765-4 CAN(29bit ID,500 Kbaud)
8.ISO15765-4 CAN(11bit ID,250 Kbaud)
9.ISO15765-4 CAN(29bit ID,250 Kbaud)
A.SAE J1939 CAN(29bit ID,250*Kbaud)
B.USER1 CAN(11*bit ID,125*Kbaud)
C.USER2 CAN(11*bit ID,50*kbaud)
*default settings(user adjustable)
Vehicle Coverage:
Works on all OBD2 Vehicles (1996 onwards in USA) and EOBD vehicles ( Petrol cars from 2001)
For your information:
For your vehicle to be OBD II compliant it must have a 16-pin DLC (Data Link Connector) under the dash and the Vehicle Emission Control Information Label must state that the vehicle is OBD II compliant.
Software Included:
Scantool_net113win (Full Version)
EasyOBDII V1.5 (Free Version)
OBD2Spy (Demo Version)
ScanMaster-ELM (Demo Version)
wOBDCRAZY (Demo Version)
.....and several more.
This hardware can match many other software still!But most of them are not free!
Works for Windows98/ME/2000/XP/Vista & 7 !
This tool does not match abs and airbag system!
Bluetooth paircode: 1234
Main Control Chip:PIC18F2480
Packing List:
A.1*EOBD / OBD2 Bluetooth Diagnostic Interface
B. 1*CD-ROM
Rs.1900 fixed, no bargain price.
SHIPPING/POSTAGE
Free shipping by courier.
CASH ON DELIVERY
Cash on delivery also possible for just Rs.100 extra.
RETURN POLICY
7 days free returns if the device is found not working. There after no returns.
If you return an item that is burnt or broken, return will not be accepted.
Returns are also not accepted if the device is simply not compatible with your car.
WARRANTY
This item is not covered by warranty. I have other ELM327 scanners that come with warranty but they are more expensive. PM, SMS or phone for information.
CAR COMPATIBILITY
As the description above says, it works on all OBD-II and EOBD compliant cars. To check if your car is compatible, please check here:
List of OBD2 and ELM327 compatible vehicles - Outils OBD Facile
P.S If you are in Lahore or Karachi, you can request a free demo before you buy.
