Par Mehran say kam hi tikkay gi bhai
100% Agreed
yes Side mirrors of JDM WR is same as PkDM WR...
Bro Where is cha sultan located in rawalpindi plz guide.
Aik meri taraf sy bhi plz
Me and my friend both two wagonRs last week and in both cars door open sign is there but donot work
Door open indication / sign is available in speedometer cluster, but not operational due to cheap economy by PS, however i think it can work only with a wire and a bulb connected to the wire which lit the dome light (in center position) on openning of any door.
Sign In | PakWheels
do you still need it?
yes i do need it bro. any clue ?
Benazir hospital on murree road also known as general hospital aus ka sath hi ha....juts ask anyone...best thing is to consult google maps...
Salam new to this thread, but i have been a silent reader of this thread..want to go for my first 1000 KM free chekup today..so plz guide what should be included in first checkup..Regards
Plug cleaning, air filter clean,nut bolt tight, computer checking, if u want then oil change, any problem u r facing u can tell them, fluids checking
Sent from my Z4 using Tapatalk
Thanx bro... your reply is highly appreciated..
Nothing special. They would inspect your car briefly, check and tighten nut bolts, check fluid levels etc. You may also discuss any issue which needs to be resolved. In my case, they hardly took 20 minutes to do so. I was having problems shifting the car in reverse gear (required some efforts), to which I got the ready-made reply that gear would become smoother than before after 5000 KMs. Changed gear oil at 5000 Kms inspection (as recommended in manual), after which it required some efforts to put the car in first gear
Dont let them open plugs in 1000km .plugs dont need to be cleaned in 1000km
They will open them, because they have nothing much to do...
Just noticed the sold mark on your ad... So the car has been sold eventually... Congrats...
I think there is no side effect of plug cleaning. Plug color shows the fuel consumption of ride.if there is a problem then they can adjust it
Nothing would happen if they open and clean the plugs. In fact, it will eliminate any possibility of missing due to spark issue.
