Check your rear tyres, is the wear uneven across its thickness ? looks like Rear wheels camber is out of specification. Any good alignment mechanic will fix it.
Must get your camber fixed before changing tyres otherwise new tyres will be ruined.
Did you keep your car on stock generals? usually they may cause early suspension wear n tear.
About the wheel bearing issue bad camber might be the cause. However cannot say with surety.
