Greenify donation with xposed framework, it wakes up greenified apps on notifications, so it never misses a notification. Its best.
Use ram expansion only when necessary, unnecessary ram swapping decreases battery timings. Just make sure to not increase swap file more than 256-512 mb. I used to keep at 256 mb. And set swappiness to 25 at max. I am using stock rom now.
Restart will take 1% charge at max, while these ram boosters noticeably decrease battery timings. Ram boosters kill apps, then the system and user apps running in high priority mode restart again seconds after killing it, increasing cpu load and battery drain, e.g, Facebook, messenger, whatsapp, viber etc. Ram boosters usually work at screen off, so this killing cycle continues for atleast 50 times a day.
So one restart daily (or once every few days) or atleast 50 times unnecessary cpu load in one day due to ram booster or battery savers? Which one do you choose?
I used to have G530F 4G variant too, i used 3C toolbox pro (Aka Android Tuner) more and after messing with everything, I learnt that Samsungs only need debloating and some UI improvements, rest things are already perfect in it.
Yeah, knox trips on rooting. Nothing to worry about. Just reflash the stock rom via Odin, it will bring it to 100% stock. You can download it from Sammobile.com, but make sure to use rom for exact model number. If it's G530H, then use rom for the Pakistan region.
Wipe cache partition after reflashing.
They will even get better after you get rid of these junk boosters. Ram expander should be used ONLY when necessary and i don't think you need it, so get rid of that too. Delete .swp file too, before uninstalling ram expander.
@512a
Its better place to discuss Rooting related stuff.
