Asalamoalikum Rahman bhai
in one of your posts u discussed engine swap of 660 jimny can u tell me a few things if u dont mind
a. wat is the model of jimny & which engine did you swap in place of 660cc
b. have u got AT or MT in 660cc . did you ratained/changing the transmission after the engine swap.
c. u have mentioned that u r swapping the 4x4 transfer case plz mention the reason.
d. after the engine swap did u keep stock differentials or changed the diffs.(both north & south)
e. ratios of stock diffs and swapped diffs (both north & south)
f. did u change (Inside diffs) only ring, pinion, both or whole assembly inside the housing
thanks :-#
