Today's updates.
The "gatri" was pushed backwards due to the impact.
It was pulled out to its earlier position.
Later the front sheet of the gatri was removed so that it can be properly repaired.
Notice the rust on the inner side of the gatri.
I was concerned about this rust but my denter said me to leave it as it is.
Any idea that what can/should be done here to prevent this rust issue?
It cannot be painted from the inner side as the outer sheet will be welded again.
The area highlighted in the red circle was pushed backwards.
It has been repaired and is back in its position.
It will be painted later on.
The area highlighted in the blue will be repaired by cutting a small piece of outer sheet in the wheel base.
