Flash code decrypt
Ten flashes of equal length=Everything OK
First flash longer than the others=Vehicle Speed Sensor(Revolution Sensor)
Second flash longer than the others=Vehicle Speed Sensor Meter
Third flash longer than the others=Throttle Position Sensor
Fourth flash longer than the others=Shift Solenoid Valve A
Fifth flash longer than the others=Shift Solenoid Valve B
Sixth flash longer than the others=Overrun Clutch Solenoid Valve
Seventh flash longer than the others=Torque Converter Clucth Solenoid Valve
Eigth flash longer than the others=Transmission Fluid Temperature Sensor And TCM Power Source
Ninth flash longer than the others=Engine Speed Signal
Tenth flash longer than the others=Line Pressure Solenoid Valve
