Thanks for elaborating. Just one more query regarding power steering fluid. Can dexron 3/atf fluid be used for power steering in honda's ? I have seen Honda's power steering running perfectly fine on dexron 3 fluid. While many people say to only use honda genuine psf otherwise you will destroy your pump and rack.
So the million dollar question is..... Can dexron 3/atf be used as power steering fluid ? Or only honda psf should be used ? If it is the latter then what is the reason for that ?
