I have recently purchased a Reborn 2006. Manual transmission and I had been facing issue with the spongy brake pedal. Several mechanics confirmed a replacement and only a kabli replacement is available.
After Installating the kabli master cylinder the brake pedal is hard and then gradually becomes spongy when I keep pressing the brake pedal and it goes down lower and lower on every press
Also the other issue is ABS is not working now and there is no fault at the ECU. ABS was working earlier still with the old Master cylinder.
Now it's just Non ABS brake and locks the front wheels..
Please advice/suggest what should be done.
I have the old cylinder with me and I have changed the 3 rubber rings of Size 3/4 kit. I want to install the old cylinder back..
