@Dyna
sadly that is one of the many things i forgot to get on my trip to europe, but there is a rumour that this stuff is available in LHR and KHI, will be fitting them and some plastic waterproofing sheets to the doors and rear panels of my car soon.
@all
here is the list of the stuff i scored on my trip:
Urethane IRS A-Arm Bush set (red)
Battery Earth Strap
Battery Tray
Brake Hose Front 1302/3 340mm
Brake Hose Rear 1302/3 250mm
MasterCylinder 1303 LHD
Urethane rear bump stops pair (black)
Engine Lid Stop
Bumper Iron Seal 1303 front (D-shaped)
Bumper Iron Seal 68-74 Rear
Bush Kit Frint Urethane 1303 1974+
Door Handle Gaskit small 68+
Door handle Gaskit Large 68+
Footwell Vent LH 8/68
Footwell Vent RH 8/68
Glovebox lock Pinch 1303 1974+
Handbrake Button Billet
Sump Plug Magnetic, chrome
Dyno/alt nut washer, chrome
Spin true Pulley Chrome
Door corner guard S/steel pair
Door Post covers s/steel pair
Door Sill covers s/steel pair
Speedo cable 1303 LHD, europe
Tyre inflation sticker
12 sticker
tappet adjustment sticker
Strut top mount 1303 73-79
Sunvisors T1, 68+ white, 1303
sunvisor clips T1, 68+ white
Urethane Grommet Knobby 1 7/8 Pair (red)
Urethane Grommet smooth 1 3/4 Pair (red)
Wiper arm LHD, lhs Black 1303 short arm
Wiper arm LHD, rhs Black 1303 long arm
Wiper caps
Anti-roll bar mounting clamps
Battery mounting Clamp
Bonnet Handle gasket, large black 68+
bonnet handle gaskit, small black 68+
Haynes manual beetle 1303 & GT Beelte
Brake Fluid reservoir cap 66+
Brake fluid reservoir filter 66+
Grab handle cover 8/67+
Pulley Billet, degree black
Crankshaft Pulley bolt chrome with washer
Door screw cover plug black 61+
Gearbox mount front 8/72+
gearbox mount, rear, L/H, 8/72+
gearbox mount, rear, R/H, 8/72+
Gearbox Seal, Nosecone to body T1, 61-79
Handbrake Grip Black, 8/67+
Coil, Flamethrower 12v, chrome 40000v
Oil Strainer 18.5mm hole
Oil change gasket set
Quick shift kit, -40%, T1, 2, 3
Seat guide Piece (upper)
Seat Gude Piece (lower)
Steering Earth strap 8/64+
Seal, rear light T1 73+
Wiper Blade, black pair
Wiper shaft seal (black)
Ignitor kit, 1971+ 12v, vacuum, replaces one piece points
Book: how to keep your volkswagen alive
engine lid handle Gasket (black) 72+
Engine surround seal T1 67+
Seal Over Gearbox
Steering U/J boots 1302/3
Now to most people these are just very trivial parts but to anyone rebuilding a VW in pakistan, this is essential kit. I hope to have it all fit soon, have done alot of it already.
