mumtaz found that the steering box had slightly moved from its original location,.. which probably explains why the steering suddenly became vague. turned out a few taps with a hammer and retightening fixed that problem.
removed the tank for better acces to the steering box,.. and we also decided to swap out the toyota/VW hybrid steering.
had to replace the outer bush on the arm, took this pic for refference (note the hole in the silencer)
time to take that horrible alteration job out of my VW
WOOHOO!! out she comes finally,.. now to revert to stock!
mumtaz checking the bush at the base, was finished so we replaced it before fitting the VW outer casing.
other side pics taken for refference, the guy on this side was faster
before you know it, the bush was in (see the red part). this guy was seriously fast. he even installed the other Bush at the same time (the 2 piece one). i'd forgotten about it so i didn't take a pic.
meanwhile on the other side,.. progress was slow.
people INSIST on fitting toyota parts to VWs for some reason,.. not thinking about the damage they are causing!!
OEM parts going in
eventually the guy form the other side came over to show this guy how it was done,... and clearly nothing had been done.
sadly it went dark and they were still working on it. but they eventually got it done. RESULT!!
