Perhaps folk's of today might not remember this car.. rest must know this... i was searching for a Carlos Sainz Celica on PW but couldn't find it so thought to share it here. I remember back in 1992-93 I use to watch the WRC only because of this car
it was one of my all-time favorites... for those who don't know Carlos Sainz was Spanish rally driver who won the WRC title for Toyota (driving a Celica) 3 times in a row (1990-92).. Toyota were so happy that they rolled out special edition Celica's in the name of Carlos Sainz, calling it a Carlos Sainz Celica GT4... It is said that Sainz still keeps a Celica GT-Four given to him by Toyota, which he drives to Real Madrid games at the Santiago Bernabéu Stadium.
here are some extracts from wikipedia:
http://en.wikipedia.org/wiki/Carlos_Sainz
Carlos Sainz Cenamor (born April 12, 1962 in Madrid, Spain) is a Spanish rally driver. He won the World Rally Championship drivers' title with Toyota in 1990 and 1992, and finished runner-up four times. Constructors' world champions to have benefited from Sainz are Subaru (1995), Toyota (1999) and Citroën (2003, 2004 and 2005).
Nicknamed El Matador, Sainz holds the WRC records for most career starts, podium finishes and points. He was also the first non-Scandinavian to win the 1000 Lakes Rally in Finland. Besides WRC successes, he has won the Race of Champions (1997) and the Asia-Pacific Rally Championship (1990). His co-drivers were Antonio Boto, Luís Moya and Marc Martí.
other details of Carlos Sainz Celica can be found at:
http://www.tccn.nl/08-gegevens/t18folderCS.htm
TOYOTA CELICA TURBO 4WD CARLOS SAINZ
Technical Specification
ENGINE 3S-GTE 4 cylinder, in-line. Turbocharger
with water cooled intercooler
Valve mechanism 4 valves per cylinder. DOHC
Bore and stroke 86 mm x 86 mm
Capacity 1998 cc
Compression ratio 8.8:1
Fuel system Electronic fuel injection
Fuel type 95 RON unleaded (3-way catalytic converter)
Ignition Transistorised
Power output 205 bhp at 6000 rpm
Torque 203 lb ft at 3200 rpm
Battery 12V 48 amp hr
Alternator 12V 80A
Maximum speed 143 mph
0-60 mph 7.6 secs
0-400 m 15.4 secs
Speeds in gears -
1st 34.8 mph
2nd 61.5 mph
3rd 93.8 mph
4th 128.6 mph
Fuel consumption- urban
23.3 mpg (12.1 litres/100 km)
56 mph 37.7 mpg (7.5 litres/100 km)
75 mph 30.1 mpg (9.4 litres/100 km)
Towing capacity with/ 1200 kg/600 kg
without brake
Fuel tank capacity 68 litres
DIMENSIONS
Length 4425 mm
Width 1745 mm
Height 1300 mm
Wheelbase 1475 mm
Track 1445 mm
Overhang Front 1000 mm
Rear 900 mm
Ground clearance 150 mm
Kerbweight Front 910 kg
Rear 610 kg
Total 1520 kg
Gross vehicle weight Front 1015 kg
Rear 875 kg
Total 1890 kg
Cd 0.35
TRANSMISSION
Clutch Diaphragm spring, single plate
Transaxle type E151F
Ratios
1st 3.583
2nd 2.045
3rd 1.333
4th 0.972
5th 0.731
Reverse 3.545
Diff ratios Front 3.933
Centre 0.341
Rear 2.928
Rear diff Torque Sensing Type
SUSPENSION
Front and rear MacPherson struts with anti-roll bars
Spring rate Front 30.0 N/mm
Rear 28.5 N/mm
Anti-roll bar front/rear Torsion, 27 mm dia/l8 mm
BRAKES
Front Ventilated discs 277 mm dia with tandem
7 in x 9 in servo assistance
Rear Discs 288 mm dia with tandem
Parking brake 170 mm drum acting on rear
STEERING
Ratio Rack and pinion 16.8:1, 2.7 turns lock to lock
Power assistance Spool Valve
Turning circle (tyre) 11.0 m
Front toe-in 0 mm
Front camber -10’
Castor 1° 10’
WHEELS AND TYRES
215/50 VR 15 Dunlop on 15 x 6.5jj
alloy wheels
Standard Equipment
Alloy wheels
Front and rear mudflaps
Colour keyed bumpers and door mirrors (electrically adjusted)
Headlamp washers
Tinted glass with laminated screen
Rear wash wipe with intermittent
3-speed wipers plus variable intermittent
Rear spoiler
Locking fuel filler with internal release
Electric aerial
Illuminated boot with tool kit
Heated rear window
50/50 split rear seats
Inertia reel seatbelts
Electronic stereo radio cassette with RDS, Dolby, 18 pre-set
stations and six speakers
Centre console/armrest with cassette storage
Cigarette lighter
Cup holder
Illuminated, lockable glove box
Sun visors with vanity mirror
Central locking
Electric windows
Tilt and slide electric sunroof
Map light
Digital clock
Panel light rheostat
Cockpit headlamp adjustment
Push button heater/ventilation controls with four speed blower
Internal releases for bonnet and boot
Tilt adjustable steering column
Passenger grab handle
Full carpeting
Cloth velour upholstery
5-way adjustable driver's seat
Lights-on audible warning
ABS braking
Power steering
Air conditioning
Leather rimmed steering wheel
Memory tilt away steering column
