Hello Pakwheels,
I am having problem diagnosing a transmission problem. I am from Lahore.
Issue Description: When driving I hear engine rev (like someone pushed down on gas pedal) just for 1-2 seconds and right at that time car transmission would shift. Right now it happens exactly at 40km/h (I hear slight engine rev for a second and along side that rev car changes the gear) and same thing happens at 60 Km/h.
Depending on how hard I push down on the gas pedal gear changing time varies.
Car Details:
Toyota Passo 2008
More Details:
-Last week I decided to go ahead and swap out my car head assembly and gear box, because both car engine and transmission were not in good condition and burning their respective oils.
-After installing kabli head-assembly and gearbox I am encountering above specified problem.
-The mechanic that installed both things and the guy I bought it from both recommended to keep driving it for at least 1000 km and insisted that this would go away with little time.
I knew the issue is not going to go away automatically still kept the car with over the weekend. Today I went back to him and demanded a different gear box. After some argument he agreed and provided with a different gearbox.
Alas after I got the gearbox swapped out the problem persists. The engine revs exactly at 40km/h and again at 60 Km/h just like before. Now I am under impression that this is not a gearbox problem.
I have been researching internet for this and erratic shifting can be caused by faulty solenoid or bad speed sensor.
I can go again and demand another gearbox, but the process of swapping out gearbox with new gear oil every time is costly and I am worried now that even third time might cause the same problem.
Can someone please recommend a transmission expert or electrician that can verify for me if this is a sensor/solenoid issue or indeed transmission issue and I should opt for replacing gearbox.
Thank you
