I have engaged one painter to remove all rust, scrap to bare metal and put primer. He is down with fever so not coming since Friday.....right hand side and rear of bus remains to be worked on, rest is all primered.
I am gathering advice on engine and gear pairing. It has its original gear box which came with its 1192 cc 36 hp engine. Bus has come with a 1500 cc dual port engine minus flywheel, pressure & clutch plate and gearbox. What do you suggest I should do.....I would like to keep the original gear in place but then it wouldn't match up with a 1500 cc.....or maybe it would. As soon as my denter and painter are back from their eid holidays, I will start on the beetle with absolute attention and keep the work on the bus ticking as well, perhaps mechanical.
