[QUOTE=AsadIshaque;3576005]The brake master cylinder was brand new.....
Generally speaking, VWs (or most old cars) must never be kept parked away for long. The brake components tend to seize up. Im guessing that's what happened here......it had rained too. Rust forms on the brake cylinder inner surfaces with the resultant friction for the brake washers/seals. Brake fluid leaks and disaster!
While assembling drum brakes, it is crucial that we use brake grease to lubricate and protect the wheel cylinders. This is Castor Oil based and not mineral oil based like most other greases. Does not eat away the rubber components. I bought a tube quite some time ago and now when I searched for it, its no longer available.
Do look for the grease if you want the brakes to last and remain reliable.[/QUOTE]
Yes it was brand new, you got it for me.
Can you recommend any other grease beside Castor?
[QUOTE=AsadIshaque;3576009]One more thing......
Never ever mix brake fluids. I do not even mix the same brand from two different sources! Always buy one brand from a single reputable buyer.
If you mix brake fluids, there is a chance of the seals going bad.[/QUOTE]
Neither do I, I always get Seiken's that too from the same shopkeeper.
[QUOTE=AsadIshaque;3576017]What is the condition of the brake wheel cylinders on the car???
If the inner bores are pitted, you will have recurring leaking brakes, a headache you want to avoid.[/QUOTE]
One is broken, the others are fine. Will get a new one tomorrow.
