@cracked
I cannot say really as my speedometer's kilometer gague has not been working properly since the overhaul. Well the mechanic said no running was required you can drive the vehicle whatever way you want, i was confused i asked him how is it possible and he said running wala daur purana tha.
I think its travelled less than 5000 km since the overhaul.
@speedster_101
I paid about 32k for the engine, well the half part i think its called upperbody or something, well the part with the piston chamber. There were other stuff as well for instance original generator etc. i can't really remember everything so the total cost with the extra stuff was 32k.
@smijaz & Xulfiqar
Well my piston chamber got damaged. According to the mechanic when the piston broke it also damaged the oil pipes within the chamber, so although it could be repaired we won't be sure if it'll work properly or not until we get it back in the car. He said it would be risky kharadia would charge you alot and we still won't know if it'll work or not so better option is to go for a new engine. So the upper part of the engine the head part only that was changed.
Engine cost = 32k
Labour and other small parts: 16k
Though the engine bay was very badly damaged so it needed some denting.
So take out 4k from that 16k, In the end total cost on the engine was 44k.
