01-02-09
Sick After So Many HOME DIY's.......Still Working On My Car DIY's.......So I Decided Today To Install Gauges......!!
Here's My Today DIY Session Shots...!!
Remove Gauges From Mounting Panel...!!
Removed Gauges....!!
Started Work Late Today.....Tired....!!
Taking Measurement To Mount The Panel.....Cluster Panels Comes In Way So Have To Mount High...!!
Left Points For Gauges In My Earlier D.I.Y.....8-| Makes It Easy....!!
Pull Connectors For Easy Connections....!!
Installed Gauge For Check...!!
Its Working Perfect....!! Showing Perfect Idle Also...!!(y)
Putted Gauges Back And Wiring Them Up...!!
Took My 45Mins Almost...!!
My Friends...My D.I.Y Tools...!!
Need Drill For Piller Hole To Mount The Gauges Panel...!!
5mm High Speed Drill Used...!!
Done.......Faded Black When Lights Are Turned Off..!!
When Lights Are Turned Onn..!!
One Rear View..!!!
Shielded Wires With Insulation Shield...!!
Closer View..!!!
Beside This...Just My Messup...!!
Bulb Torch Converted Into LED One......More Light...Longer Battery Life....!!
Custom Button Putted.....
Thats A Gift For Me From One Of My Friend For My 20v...!!
Thanks Friend...
Thats All For Today's DIY...!!
Looking Forward For Tuning Session And Putted More Things Inn...!!
Regards
