Day 10 Swap Started
Early In Morning.....Its Time To Toe It And Take It Where Mounts And Down-piping Work Is Gonna Take Place....!
So I Toe It With My Sunny And Heads Toward Destination...!
Here Its On Way...
After Couple Of Hours...Old 2E-LU Is Finally Out To Say..Good Bye..
You Have Done Your Job..Now Let 4A Bro To Have Some Fun
Engine Room Empty..You Can Also See Steering Rack..Its Gonna Be Installed In Place Of Old One Which Is Leaking Oil...I Grab This One Of AE101....!
After Removing Pipes From 20V BT...The Internal Condition Of Water Flange...
See How Clean It Is From Inside..MASHALLAH ...!
Finally 20V Inn....!Balancing Engine & Matching Mounts Location Making Sure Axles Also Gets Into Proper Direction...!
Engine Mounts..Old Ones...Have To Find A Good Set Of 4...!
Side Looks...Engine Looks Like Its Being FF Into It
MASHALLAH.. Also You Can See Ustaad Taking Measurements...!
Side View Along With Shiny Flange Ends
Some Things I Found There...!
Lolx...Coincident....20v ST for Swap Out There
RX-7 Tranny Lying Out There..To Have Some Fittings...!
Almost Hand Made Jeep With Hiace Engine....Big Project..!
Thats All For Day 10.....
Regard
