last month my uncle bought a 1997 pradoand i take it to the first long trip of 1100 kms in 2 days full of jugars(H)i havent pics right now of these jugars but will post soon as i get them from my cousin coz snaped by himi started my journey from multan to lahore and back to bhawalpur and then multani started at 2:00 am from multan and after travelling 10 kms the right side headlight turned offstopped it and opened bonnet ahh the wiring holder was so hot.put it on with the help of cloth and start travelling agin but again after a bump it failed.stopped at a fuel station and opened bonnet again the holder became loose.my cousin was smoking at the time.idea came to my mind.get the cigrrete pack from him and fitted in between the body and holder and yeh it worked for whole tour and my cousin "o meri Dunhill yar 2 cigreete andar he the"2nd at sahiwal after break fast my cousin get his hand on the driver side mirror and it fell down as a whole from its assemblyMy God it was retractable yar.now wiring was with the mirror also.what can i do not to put her aside because of wiring.started journey again but i seem completely blind without driver side mirrorstopped again infront of Bata Factory and their stores.a taxi wala helped me and give me a white band which is used to tie the wirings and wheels cups and with the help of that i hanged it at its orignal position till Multan again and was more gripped than any orignal
This is gonna be hilarious my class mate has a lovely all jenian 2005 mehran it was exam days june time he asks me after paper come with me my car broke down and is parked in a teachers colony so we went there and i try to start it but self le k gari band and he was telling me that it has bad head gasket over heat hogai hai i turned key and kept it there and gari self bhi le rahi hai and it is started i gave few pumps to acclearator and no smoke but as soon as i left the key it turns off there were some uni bus drivers and one bus mechnic what he does is he managed to sit inside engine bay and starts beating self motor like us ne bandy ko gali de hai and his logic is that self is stuck i am beating it it was clear to me that it has an electrical fault not mechnical i called my electrition and told him situation and still that guy is beating self like hell i pull him off the car and telling him bhai da Hino da de he tells me connect positive terminal of battery with +ve of coil and there is no wire i managed to find pieces of wire but not long enough there was construction going on in a nearbuy area one of drivers went there and took of 2 meters of wires LAMO i am installing the wire and the guy who was beating self is yelling k mera nam badal dena agar yeh start hogai it will not start za na manamand it did started with wire connected and my class mate left to electricionthe self harraser went what did u do to it how it started LAMO
My indicator's grip lock was broken so did this TOTKA to get it adhere with headlight
Today saw a mechanic using engine oil for diesel car in a petrol engine suzuki bolan upon asking why he replies it will cure the issue of excessive engine noise. :o
RIP engineAnd all those noises will now be converted to owner's Pain In the ***
Not done with car but Nokia 1616. One of its charging pin was broken so used Stapler pin and it works like a charm
Saw a mechanic using two condensers instead of one for better ignition system. -#
Nice
Errmmm - Condenser? And ignition system??
condenser point distributor k sath laga hota hai. google ignition system or condenser
Using cover of a notebook (aka "patla gatta" in local language) along-with silicone for making engine oil seals of old cars to avoid khuwari of searching their seals in market.
some time back I was in a rishwa and the was fully beaten up in the end when I reached home was giving him the fair (keraya) I saw he cluth lever was free and was being hold by a elastic bent (in urdu zerban :D)
Lol, and that works??
that is being super stupid, one can buy a whole sheet of gasket paper and make all the gaskets you want for cheap.
I saw an old Bedford truck wala rubbing potatoes on the wind screen, no wipers it works perfectly as a rain repellent apparently.
What sort of Diesel oil? You're on thin ice pals, tread carefully
Well I'm using delo in margalla, better than regular havoline, atleast for my old car.
Delo and delvac can be used in petrol engine
Pardon the necro-ing but doesn't this process of heating and dipping in water makes things more brittle instead of softer?
Saw people pouring water on hot brakes coming down-hill from Murree old route to cool them down.
i am using delo gold in my car and its done about 1.5k till now and Alhumdullilah now issues or problems faced so farinfact my car is returning better fuel economy
