Can be put underground in walls just like as of water pipes. Not to be buried in concrete as in case of any issue concrete breakage will be an issue.
As far leakage is concerned, if work done by good team, joints work done at required temp and air pressure test done prior to plaster, chances of re work will be minimum. Thanks
