actually its not dynamat's fault..there are two very important things:
1) surface should be 110% clean. even a slight dirt or grease will kill the whole application...this much cleaning requires alot of hardwork. open your door panels and u will see what i am talking about. might need to use some chemicals, acetone etc to cut the dirt and grease...
2) need to use heatgun/hairdryer to make the adehsive stick to the metal surface properly. this can take quite a bit of time and effort as well
its a purely DIY venture. these audio wallahs can never do it for u. if the above to points are well taken care of, ur dynamat wont cause u any problems
