i am thinking of buying this shaft from somewhere , previous owner have messed up with this thing .
Any idea for how much would I be able to get a new / used rear trunk glass of alto 2009 ?
Sent from my A900 using Tapatalk
anyone using 20w50 oil in 660cc Alto? I am getting a noise from the engine....looks like the engine is 100,000 KM old now.... or shall I continue with 10w40?
Do not change to thicker oil as long as engine is not consuming oil.
I am getting 18 KM/L and its a 4WD. very much satisfied I was in a panic when i purchased this car as everyone was saying this and that etc...but after a week, i am very much satisfied.
excellent good average.......... how did u calculate average???????
Haha, good to know:) A member posted that 4WD only gets active when in first gear or in reverse:P So that probably explains it!
Calculate your average again....Its impossible.!
its 100% correct and verified twice. Only thing i did was tuning and oil change. The best part of the tuning was cleaning of the plugs and a new air filter....even before the tuning i was getting 16.5 KM/L. I filled in 7 litres of petrol immediately after the car fuel light went ON...turned the trip meter to zero and then waited until the light turned ON again after covering 124 KMs.... 124/7 = 17.7 KM/L
Light foot drive can achieve that. its 4WD Alto G-II.
+ The driving area is RWP/ISB... Westridge (RWP) --> IJP Road --> Faizabad --> Chak Shahzad.
In my car sometimes the light turns on early sometimes late , fill the tank (FULL) and let it come to half ,check kms and check how many liters fill up , divide and then check
will try that too...But interestingly, i also observed the fuel needle, it was on the same position when the light turned ON for the second time as where it was when it was turned ON at the first time...I will fill the tank this time Full and will share the findings here
My route is Isb - G9I-8/2 - Chakshahzad Still stuck at 16 kmWith a/c 12-12.5 max
[QUOTE=expertshani;4288163]its 100% correct and verified twice. Only thing i did was tuning and oil change. The best part of the tuning was cleaning of the plugs and a new air filter....even before the tuning i was getting 16.5 KM/L. I filled in 7 litres of petrol immediately after the car fuel light went ON...turned the trip meter to zero and then waited until the light turned ON again after covering 124 KMs.... 124/7 = 17.7 KM/L
Light foot drive can achieve that. its 4WD Alto G-II.[/QUOaThis not right way to calculate average,
where do i can find the 4x4 shaft of Nissan Pino and how much it will cost me ... my shaft is missing
Its removed to make your car 2wd and if you install it , your avg would be reduced Sultan ka kho (Rwp)Bilal Gunj (Lhr)
bhai i am concerned for why one original thing is removed ... this car is designed for the 4 wheels , originally it's not a 2x2 wheels drive ... so the car must be in it's original state .. that's why i want to fix it again ..
Go spend some money and fix it
I am selling my JDM Alto 2008, if anybody interested, he can have a look at this add.Thanks
Used Suzuki Alto ECO 2008 Car for sale in Islamabad - 805198 | PakWheels
Which oil did u use? Share name & specs of oil.
