@ch.talal
I have purchased different types of silicones & elfy and gave to Mechanic whichever they demand like. As he has opened different engine components so I have tested and used Dirko & Mannol brands in 3-4 different variants like Mannol 9912, Mannol 9914, Mannol 9916 with Liquid Moly Aerosol Si Spray+ Liquid Moly Leak stop(also known as Gear Leak Stop).
For final outer covering at various places + fixing of loosing indicator cover, bought locally blended Si by Harris
After these efforts, only thing lacking was under sized & oversized distributor inner seal
@abid110
I have seen Guard oil but DIL NAHI MANTA for use as being a local brand
@s15
No bro, i am continously changing distributor inner seal
@harryberry15
I am surprised that it seems you have not changed you oil once by 3s or 2s suzuki dealers. Anyways der aeed durust aeed. I also did this mistake of using wrong API rating but when suzuki dealer guided me + pakwheelers strongly advocated then i converted back to API SG 10W-40.
Hydraulic lifter specially carby engines like yours need certain ZDDP amount which is not present in newer grades(I think due to Environmental issues) so that is the reason why we have no choice other than SG or SJ
I used Shell yellow pack before SGP but when i converted, believe me u will also feel reasonable difference.
@sayedgulhassan
I have doubt as mechanic told me that this dist. assembly & seal is present in efi models only
