i am not sure if it would bolt right up, even if it did, the combustion chamber volume may be off and may raise compression ratio too much
or valves could hit the piston
or you could get lucky if it worked
But even if the g13bb and g10b heads were same ,it is not a smart idea to run the cultus ecu on the baleno engine. It would run poorly and lean or in open loop (check light)
