Pls correct my understanding if its not right
I have 2008 EFI, of which both radiator and condenser fan works separately independently as required... Meaning the radiator fan will switch on and off as per coolant\engine temperature, irrespective if AC is on or off, right?... While the AC fan will work as per its own set up.
Some owners are having a different setup though... That is when AC is on the radiator fan also switches on... Meaning whatever the coolant\engine Temperature is, radiator fan will turn on too... Those owners say this setup improves AC cooling.... Does it really affect?
My understanding is both fans as per factory setup run separately, and there cannot be any improvement in AC cooling if radiator fan turns on too, cause AC has it own fan for the heat transfer from condenser.. and changing this setup may later on cause problems of engine running colder when AC is on, right?
Pls enlighten
