Weird problem is happening in my cultus efi electrical system,A/c turns On and off on its own even A/c switch is turned off, It's happening after car gets warm, Replaced the A/c relay problem still persists, weird thing is it's not happening constantly so when I visited the electrician it was completely fine and on my way back it started again, Car runs perfectly fine with A/c ON when it engages on its own car rpms gets dropped and weird A/c clutch started engages and disengages and weird sounds from A/c clutch, I checked it on the scanner (sz viewer)when it happens ecu isn't-recognizing A/c is ON or clutch Magnet is engaged
